Anyone know any software that can merge multiple monitors so the system recognizes them as one? So If I have 2,3 or 10 it merges their resolutions into one. Cheers
For what you'ld spend on a new high end video card and 3 monitors...I would buy an led 40" to 50 1080p screen..
It might be a bit more but you wouldn't have the anoying bezels to bother you!!!
Even at 32" it's pretty awesome gaming.....
Hope this helps...
JQ
I disagree. I'd rather have the extra screen space then the bigger screen. I really want to see someone who is using three 1080 projectors to do eyefinity. Three 80inch screens doing 1920x1080 each for a massive 240" 5760x1080 "screen" would be incredible.
