Solved
What power supply will i need?
Last response: in Components
Best solution
A good quality psu around 400w is all you need.
Good budget psu's of quality build i usually recommend is these two.
Corsair CX 430 V2
Antec EA 380D/430D
And if you have a bigger budget and want something really efficient...
Corsair CX 430 V2
Antec EA 380D/430D
Fanless series is considered one of the best and I do tend to agree with you but considering he wants an AMD build most likely he is vying for a very budget build.
Related ressources
The Antec Earthwatts 380W PSU is excellent. It's actually made by Seasonic a top tier PSU manufacturer.
But be warned Earthwatts PSUs do NOT come with a power cable, that has to be bought separate(usually around 4.99)
Ask the community
