Can anyone help me with a PC Power Supply Compatibility problem.
I have an ASUS P4C800-E Deluxe motherboard. The Turbo-Cool 510 SLI Power Supply that I was using failed.
I ordered a Corsair CMPSU-750AX power supply. After I unpacked the unit, I had a couple a minor questions about the cables and sent an email to the Corsair tech support.
They replied almost instantly with the answers and added that the new Corsair power supply would not work with the ASUS motherboard. The power supply was ATX v2.3 Spec. and was not backward compatible with the ATX v1.3 Spec. motherboard.
The only new ATX v1.3 power supply I can find is a Rosewill 350 watt unit. I already know that 350 watts will not run my PC.
Is anyone aware of any ATX versions that came out after v1.3 that are backward compatible with the v1.3?
Maybe it will increase the chances of finding something that will work if there were a greater number of ATX versions to select from.
Thank you.
Thank you.
