Hey guys I am getting the urge to build/upgrade my computer and I have put together something and was hoping you guys can tell me if the items are compatible/suggest something better. thx
this will be for gaming mostly and hoping will last few years
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core
ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Microsoft Windows 7 Professional SP1 64-bit - OEM
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Now these are my old hardware that I am hoping I can still use with the upgrades above
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
SAMSUNG SpinPoint T Series 500GB 7200 RPM SATA 3.0Gb/s 3.5" (This one has Windows Vista 32bit)
SAMSUNG Spinpoint F1 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
SAMSUNG Spinpoint F3 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
SAMSUNG 18X DVD±R DVD Burner with LightScribe Black SATA Model SH-S183L LightScribe Support - OEM
SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
OCZ GameXStream OCZ700GXSSLI 700W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
HIS H485QT512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support IceQ4 Turbo Video Card
I plan to get a better gpu in November.
My main concern is if I order all those new parts and set everything up will everything go along? Thx alot
