Solved
Will this Power Supply work with this motherboard setup?
Hello,
Just a quick question about a PSU working with a motherboard. I am 99% sure it will work but having another set of eyes doesn't hurt when it comes to building a system.
I am using a server motherboard.
http://www.supermicro.com/products/motherboard/QPI/5500/X8DT3-LN4F.cfm
I will be equipped with 2 Quad core Xeon CPUs (E5504) and 12 Gigs of Ram ( 6 Gigs for each CPU )
I will be using an old Sound Blaster card in the PCI slot and a video card in the PCIeX16 slot. I Have not decided on the video card yet. For now, I will be throwing in an older GTS250
I'll be running an SSD for the boot drive and a 2TB for storage for now. Will most likely move to the onboard raid down the line
It will also house a sata DVD burner.
The only thing missing is the power supply.
Here is what I am thinking
http://www.newegg.com/Product/Product.aspx?Item=N82E16817338012
It has the 3 connections to the motherboard I need. 1x24 pin and 2x8 pin
It also has a connection for the video card power. 600 Watts should be enough to power this system.
Can anyone see any issues with this as the power supply?
Thanks
7 answers Last reply Best Answer
More about will power supply work motherboard setup
  1. Did you read the feedback on that PSU! Low quality with no 80+ certification and passive pfc (input voltage selector switch) http://www.endpcnoise.com/cgi-bin/e/faqpfc.html
  2. Ahhh, that I did not do. I was just happy to find a power supply that I could fit into a tower system that could power the board. Any suggestions on a reliable PSU or should I keep looking?
  3. Best answer
  4. Thank you very much for the posts.
    I had no idea they made an 8-pin Y cable
    I'm glad I waited to pull the trigger until I posted here.
    That FSP600-80PSA really looks good as well.
    Thank you
  5. na the fsp is pretty mediocre
    i'd get this
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
  6. Best answer selected by mail4youtoo.
New Build Power Supplies Graphics Cards Motherboards Systems Product
