So here is my situation. Last time I built a gaming system it was about 6 years ago and turned out great. Now since then I haven't had much time to stay up with the technology but have been doing a lot of reading the last week or so. I have been going through Newegg and put everything into my cart and came out around 2k which was what I was looking to stay around. Below is the specs of the build. I am looking for feedback and suggestions.
I would like to buy within the next couple weeks.
This will mainly be used for gaming although I may use it to run as my HTPC also and retire my Revo that currently acting as it. I would ultimately like to also get a second SSD and install Apple OSX to it, or have it run through a Virtual Machine maybe (better HTPC software). If it makes a viable HTPC when I am not gaming on it I would also like to explore the ability to have it act as a DVR for me if I add more storage drives for it. Lastly, I would also like to use it for Folding@Home.
[strike]Case: Corsair Obsidian Series 800D CC800DW Black Aluminum / Steel ATX Full Tower Computer Case $270
Storage Drive: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $90
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-8GBXH $130
MoBo: ASRock Z68 Extreme4 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $190
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K $315
CPU Cooler: XIGMATEK Gaia SD1283 120mm Long Life Bearing CPU Cooler bracket included I7 i5 775 1155 AMD and dual fan push pull compatible $30
OS Drive: ADATA S599 AS599S-64GM-C 2.5" 64GB SATA II Internal Solid State Drive (SSD) $120
Now for Graphics Card(s)...
2 x MSI R6970-2PM2D2GD5 Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity $680
or
1 x Galaxy 58NLH5HS3PXZ GeForce GTX 580 (Fermi) 1536MB 384-bit DDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card $460[/strike]
Revised build list below!
And for the power supply I am looking for suggestions... Right now I am going to be running air cooling but I would also like to try my hand at water cooling once I have a little more money down the line (Hence the case selection).
The main game I will be playing that is graphics intensive is BF3 most likely for now. I will be running two monitors at 1650x1080 resolution also most likely. Also my OS will be Win 7 professional.
This build before rebates is showing at around $1600 - $1825 (depending on graphics card choices and still needing a power supply).
What do you think?
or
What do you think?
