I recently posted about my computer being stuck in loop, turning on and off repeatedly, this was because my CPU was incompatible with my MOBO. It was resolved by flashing the BOIS with the update and my computer worked fine, installed windows 7 64 bit, and several programs, all the components of my computer worked perfectly fine.
My hardware:
4x4GB g.skill ripgaw 2133 mhz (running at 1600)
ASUS P8Z68-v
gigabyte Radeon 6850
intel i5-3570k
fresh 500gb hdd
corsair tx650 PSU
Now my problem, I was installing updates to my computer just before I went to sleep, it eventually finished and straight after my computer turned on again. Neither the power button or the power button on my MOBO would turn it off and so I had to switch it off at the back. This problem was made worse by the fact that both my onboard graphics and my graphics card stopped working. just before anyone states the ordinary stuff I must check, I have already gone though this whole list:
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems
And checked them ALL.
It's currently in a breadboard state with nothing but a CPU and 1 stick of RAM. I've successfully got BIOS to come up by re-setting the CLRTC pins and removing the battery, whilst I was there I checked that there is no setting enabled that can wake the computer and I've also tried re-flashing the MOBO with no success. Once I turn the computer off it automatically restarts 2 seconds later, no graphics and same symptoms as before.
My hardware:
ASUS P8Z68-v
intel i5-3570k
fresh 500gb hdd
corsair tx650 PSU
