Will this work ? :D Please help
Last response: in Systems
Anonymous
a b U Graphics card
a b V Motherboard
June 25, 2011 1:32:49 PM
at the moment i have
mother board : Board: Gigabyte Technology Co., Ltd. M68MT-S2 (not the best)
8gb of ram
amd phenom II x4 955 Proccessor
(crap graphics card)
i want to add this anything i am missing or will need please help
http://cgi.ebay.co.uk/NEW-EVGA-GeForce-GTX-570-HD-SC-Gr...
http://cgi.ebay.co.uk/AMD-Phenom-II-X6-Six-Core-1090T-3...
http://www.amazon.co.uk/Corsair-Power-Supply-Version-CM...
More about : work
a b U Graphics card
a b V Motherboard
June 25, 2011 1:52:38 PM
I would skip the Phenom II x6, unless you are running some really threaded applications the 955 BE is just as good for you. With Bulldozer around the corner quite likely not worth the investment.
The 650W Corsair PSU will run the 570 just fine.
Just make sure your case can fit the 9" long card, most cases should, but it never hurts to check.
Otherwise things seems to be compatible and should give you quite a boost, depending on what your definition of crap graphics card is :)
Anonymous
a b U Graphics card
a b V Motherboard
June 25, 2011 1:57:11 PM
ps3 hacker thank you lol i will be shoping there now and Rvilkman thanks for the advice
a b U Graphics card
a b V Motherboard
June 25, 2011 2:35:12 PM
Since he listed that he already has the 955 getting the little benefit does end up costing a lot of money. Thus why I recommended skipping it.
a b U Graphics card
a b V Motherboard
June 25, 2011 2:39:30 PM
lol didnt read that, yeah, if he already has a phenom 955 then it would be pointless upgrading to a 1090T.
