Are these power supplies trustworthy?
  • Power Supplies
  • Components
  • Product
Last response: in Components
September 20, 2011 7:53:52 PM
After receiving very negative feedback with every post I've put up even mentioning my power supply (OCZ ModXstream Pro 700w) about it, I've decided I should return it for a better one. I need at least 700w, connectors for 2 gpus, modular, and it has to be within $20 of the modxstream. The only thing I can find that can fit those criteria are the Rosewill Hive 750w or the http://www.microcenter.com/single_product_results.phtml... (the second of which I'm not too sure about). If you know whether these are good or if they don't live up to their expectations, please post. Thanks!
More about : power supplies trustworthy
September 20, 2011 8:25:30 PM
Get a Cooler Master Silent Pro
m
l
September 20, 2011 8:32:59 PM
it has to be under $100
m
l
a c 87 ) Power supply
September 20, 2011 9:34:04 PM
The Rosewill Hive apparently shares the same internal design as the OCZ ZS series, which is getting positive reviews, so I'd say that is your best option.
I would not buy a Cooler Master eXtreme Power unit for myself, as other units in that series haven't reviewed well, so I wouldn't recommend them.
What two GPUs are you planning to buy/use?
m
l
September 20, 2011 9:37:07 PM
I'm definitely leaning towards the hive. That was my original choice but I was at microcenter and the psu I have now was on sale so I got it instead. Not really a good decision.. does anyone know if microcenter will take back a product if the rebate has been sent it?
m
l
September 21, 2011 2:19:09 AM
Another solution which would be easier so I don't have to wait for the power supply to be delivered is the thermaltake tr2 rx 750w. http://www.microcenter.com/single_product_results.phtml... and if that has good reviews I'll most likely go with that. Does anyone know anything about it?
m
l
a b ) Power supply
September 21, 2011 4:23:27 AM
its a pretty good fire cracker blows up at 650 watts but is out of spec at 500 watts
m
l
September 21, 2011 4:35:18 AM
Game killer. Good luck.
For the record, I think Microcenter has the (Mk. I) Silencer 760 on sale. I don't think I've yet seen a review to see if it's a match for the pre-MK. II Silencers, but there ya' go.
m
l
a b ) Power supply
September 21, 2011 8:45:26 AM
never skimp on a psu, it will outlast every other part of your system and you will be able to reuse it future builds.
m
l
October 3, 2011 2:31:58 AM
I saved a little more and decided on a Corsair GS800. Thanks everyone!
m
l
