So heres my problem. i bought a new CPU,CPU Cooler,Mobo and RAM, and i finished the build, but i started her up, and she wouldnt post (not having a sys speaker on me...) i did a few test with it, taking out all sticks of RAM GPU HDD's ect and try to boot.
Anyway so after 6 hours of trying to solve this, i thought the Motherboard was Faulty, so i returned it and got it exchanged.
So i came back to do the new build with this new motherboard... same problem, wont post at all, no matter what i do.
So i went to a shop 40 mins away to buy a system speaker to diagnose, When i have everything plugged up, (not includding Drives) the Speakers doesnt beep, its just silent.
So outta curiousity i took out the RAM... And it done Short Beeps constantly meaning it RAM was missing. So i put back in the RAM, and it doesnt beep.... SO THAN, i removed everything besides Mobo, CPU and RAM... (removed the GPU)... Still no Beeps...
But as soon as i take out the RAM it does beep.
I than went on to test the RAM in 2 other PC's, the RAM Worked fine, tried using different monitors same thing.
PC Specs (NEW BUILD):
CPU: i7 3820
Mobo: GB X79-UD3
RAM: Patriot Gamer2 (4gb stick 1600mhz)
PSU: Huntkey 650w
HDD's: 3x WD Green
DVD Drive: LG DVD/rw
Case: Antec 902 (modded)
I need help asap, as if i go to the shop tommorow (a long drive away) they have said they will/can replace the part.
EDIT: I have cleared CMOS/BIOS mutiple times including everytime changing a DIMM for RAM (i tried the stick in every DIMM)
CPU: i7 3820
Mobo: GB X79-UD3
PSU: Huntkey 650w
HDD's: 3x WD Green
