I just finished my parts list for my home built system. Could you please check over them for me so I know that they are all compatible.
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028 530W PSU $40
GPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=621465&sku=V261-5674 Visiontek ATI Radeon HD 5670 $60
Disk: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6078414&sku=A455-5022 Asus DvD+CD RW $20
Ram: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6613461&sku=C13-1005 4GB DDR3 $30
Motherboard; earlier I asked for suggestions so I put together a list and wanted to know which one I should go with. I believe all are compatible with my GPU. Is my CPU compatible with all, though?
-http://www.tigerdirect.com/applicat...s.asp?EdpNo=6470640&sku=M452-6101 MSI 870-G45 $70
-http://www.newegg.com/Product/Product.aspx?Item=N82E16813157198
-http://www.newegg.com/Product/Product.aspx?Item=N82E16813138283
-http://www.newegg.com/Product/Product.aspx?Item=N82E16813138318
-http://www.newegg.com/Product/Product.aspx?Item=N82E16813130560
CPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7023169&sku=A79-1100 AMD Phenom II 1100T Black Edition Six Core $190
Case: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6430030&sku=C283-3122 Cooler Master RC-430-KWN1 Elite 430 Mid Tower ATX Case $40
OS: Windows 7 Home Premium 64Bit (OEM) $100
Total: Around $615 after rebates w/ shipping+tax. This price sounded phenomenal compared to the prebuilt, refurbished system I was going to originally buy from asus, which would have needed a new PSU, GPU, and only had a 1045T processor.
Does this system look reliable, fast, and primarily future proof? I want to make sure that the motherboard will be able to stay without being upgraded because by buying the OEM form of Windows, changing the board will force me into buying another copy..
Note: I have many hard drives lying around which is why there are none on my list.
My use for this PC is for HD video editing in programs such as adobe after effects, adobe premiere pro, and sony vegas. I will also use it for streaming HD content from Hulu. If it has the capabilities, I will use it for gaming, I'm not much of a gamer though, so probably minecraft on max settings . Does my GPU+CPU look like it could handle those?
If you see anything that you'd like to replace etc. please do. I really don't want to go any higher on price, though.
Thanks!
Johnny
Thanks!
Johnny
