Booting Problem with graphics card
Hi guys. I just bought a Asus M5A78L-M LX motherboard, cause my last one stoped working. Só i instaled it and everything. Working fine. But when i tryed to put in my graphics card ATI Radeon HD 5750 ( bought 2 years ago) my pc just wont start. Even if the card is on but without power, the pc wont go. I need to take it off the PCI-E slot to work. I'd like to know if anyone has any information on the compatibility of this motherboard with grafics cards or any other help would be great!
Thanks.
Graphics card Expert
Motherboard Master
Welcome to Tom's Forum! :)
ASUS M5A78L-M LX - http://www.asus.com/Motherboards/AMD_AM3Plus/M5A78LM_LX...
There's no 'compatibility' reason for the HD 5750 not to work and the MOBO to post. The typical HD 5750 has one 6-pin PCIe power connection that must be used and connected to the PSU to work. Therefore, make certain the GPU has it's 6-pin connected, and it's properly seated in the MOBO's PCIe slot (top-long dark blue slot) and the MOBO's PCIe lock is engaged.
If it fails then I would try the GPU installed in another PC to see it works. My feeling if properly connected (6-pin) and seated (PCIe slot) is that the HD 5750 is damaged -- RMA is under warranty.
Yes, that is pretty much what i thought. Im gonna try to test the gpu on a friends computer. Ill also try the bios settings.... Maybe its confugred not to start with other gpus then the onboard one. I hope i can make it work, cause it is practcly the price of my whole pc (cpu, mobo, ram, cd, tower together), i dont want to have to buy another one ... Thank god i already had a hd.
Anyways, thanks for the reply. Ill post here if i find a solution.
Motherboard Master
I looked at the manual when I first replied, by Default the GPU is initialized first. If it's the GPU then most are covered with a 3 year warranty and some longer...if it fails then RMA.
Ask the community
