Graphic card power
ENGTX460 DirectCU/G/2DI/1GD5
do I need to plug power into 1 slot on the card or do i need to supply power to both?
4 answers Last reply
More about graphic card power
  1. both *2x6 pins*
  2. the best would be to plug power on both... this will make sure that the card has all the power power it requires so that i can run on its full potential... and if your overclocking the card then def plug on both slots
  3. Thx all I found out that it wont run on one power plug
  4. You need both, even if you use a 4pin molex to 6 pin PCI-E adapter. It has 2, it needs 2.
Graphics Cards Power Graphics
