Hi there. So my computer runs great. I'm running with dual gtx 560 ti cards and have had no problems at all. Problem is, Starcraft 2 doesn't support SLI, so when I play I have to disable it. Game runs great for a while, but the screen starts going completely blank for 10 seconds or so every now and then, then continues to run good for a while, then does the same thing. Over and over. It's like its trying to run off both cards, but not at the same time. Like it's switching between them. Does anyone have a solution to this problem? Thanks.
Edit: I believe it is a problem with the disabled SLI because before I realized it was originally disabled I was playing Crysis 2 and I had the same problem.
