Hi,
Really hoping someone can give me a hand here. This is my second Z68 Extreme3 with the same exact problem.
Setup:
ASRock Z68 Extreme3 Gen3
Intel i2500k
4x G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) F3-10666CL7D-8GBRH
My problem is that the board will not POST with ANY memory sticks in the A1/A2 slots. The board will only post if I put RAM in the B1/B2 slots. I can successfully post with two 4GB sticks in each B1 and B2, although this is obviously single channel. The same two sticks in the A1/A2 slots result in a Dr. Debug "45" code. I have read that others had this problem with the board, so I RMA'd it. The new one does the exact same thing. While the machine would POST with single channel.. I found that it was somewhat unstable in Win7.. locking up, etc. Two of these memory modules are brand new and have never been used.
I have everything mounted properly in my Antec P183 V3, and have ensured that the screws aren't super tight so the board won't short. One thing that I did notice is that the screws that came with my case are a bit large, and are very close to touching some components on the board. For the fear of shorting the board out, I made sure that the screws were very lose.
Does anyone have any ideas what I can try? Could it just be that the memory is not compatible? If that were the case, would it even work in the B1/B2 slots?
Thanks.
Setup:
Intel i2500k
Thanks.
