Should i connect the case fan into the power supply or the mobo?
Last response: in Components
- How to connect molex case fans to fan controller and power supply? - Forum
- How To Connect Case Fans To Power Supply HELP!! - Forum
- How many case fans can i connect to the power supply? - Forum
- Power supply doesn't have connections for case fan - Forum
- problem i cannot connect a Fan with 2 wire(red and Black) to power supply. - Forum
- How to connect case fans mobo pins or PSU power? Forum
- SolvedConnecting case fans directly to power supply? Forum
- SolvedHow to connect two 4-pin case fans to one case fan port on the mobo? Forum
- SolvedI don't know what case power supply and fan to use... Forum
- Solvedshould i replace my power supply or case ? Forum
- Connecting case fans to Motherboard & power supply Forum
- Connecting case fans to power supply? Ran out of space on motherboard! Forum
- Solvedhow can I connect 3 pin fan to power supply? Forum
- Case Fan Connectors Wont Connect to my Mobo or PSU Forum
- SolvedNeed help with NZXT H 440 case, don't know how to power/connect the fans Forum
- SolvedWhere to connect case fan on mobo? Forum
- Need help choosing a mobo, power supply and case for gaming PC Forum
- SolvedPower supply LED blinks when connected to motherboard but it stays lit and fan spins with paperclip test Forum
- SolvedCooling the rig. Should i connect the fans to the motherboard or the case ? Forum
- More resources
Read discussions in other Components categories
