So I want to make a gaming computer myself for the first time, I study IT but follow the Software side.
So I browsed through some hardware and I ended up with this configuration, using only the limited teachings about hardware that I know... I would really appreciate if you could help me by telling if these parts would match and what you recommend on these settings, my budget is a max of thousand pounds.
Personal Preference from high to low : GPU, CPU, RAM, Cooling, Motherboard, Case, Hard-Disk
GPU :
XFX HD6950 Dual Fan (HD-695X-CDFC) (2x DVI, HDMI, 2x Mini-DP, CrossFireX)
Based on the AMD Radeon HD6950 Chip
has over 2048 MB GDDR5 Memory, 256 bit wide interface.
111 x 38 x 256 mm
CPU :
Intel Core i5-2500k
4x 3300 MHz
4x 256 KB Level 2 cache
6144 kB Level 3 cache
RAM :
Ripjaws G.Skill 2x4 GB DDR3-1600 MHz
ASRock P67 Extreme4 (B3) (FW, RAID, Gb-LAN, Sound, ATX)
More Info...
Power Supply :
OCZ ModXStream Pro 600W (1x PCIe, 1x 6+2-pin PCIe)
150 x 86 x 165 mm
Case :
Aerocool Vx-e
Five 5.25" Bays
Supports Large High-End VGA Cards Up to 290mm
Includes 4 sets of 5.25" Adapters for HDDs & FDD
I/O Panel Includes USB, Audio, and Mic
Up to 5 Fans
196 x 452 x 539 mm
Hard Drive :
Western Digital WD1002FAEX (SATA 600)
1000 GB
7200 rpm
4,2 ms
64 mb cache
102 x 26 x 147 mm
DVD-Writer
ASUS DRW-24B3ST (12x DVD-RAM)
All together this is about 850 pounds.
1) Are these a good hardware configuration to be able to build a pc myself? I think so but somehow I still have doubts.
2) the RAM cards sound promising, but are pretty cheap, are these bad ones or are RAM cards just cheap at the moment.
3) What would these configuration be good at and where would it fail in?
I am sorry that my English isn't perfect and I am sorry if I give redundant information. I am not sure what some of this information means and what exactly is important.
I really appreciate your time to help me so thanks in advance!
GPU :
111 x 38 x 256 mm
CPU :
Intel Core i5-2500k
4x 3300 MHz
RAM :
More Info...
Power Supply :
150 x 86 x 165 mm
Case :
Aerocool Vx-e
Five 5.25" Bays
Up to 5 Fans
196 x 452 x 539 mm
Hard Drive :
1000 GB
7200 rpm
4,2 ms
64 mb cache
102 x 26 x 147 mm
DVD-Writer
