Dear gentlemen,
please assist me in determining the source of my problem.
The problem: computer locks up (freezes), stops responding completely. No BSOD, no black screen (just the still image of the last frame before the lock up). No buttons work, only power down helps.
When can the problem be reproduced: The PC was build in December 2011, but the problem first appeared after a week of playing Diablo 3 (May 2012). However, the problem can be reproduced by: 1. Running 3dmark 11 (sometimes it completes successfully, but generally locks up at Combined test), 2. Running Furmark 15-minute stress test (always a lock up after about 15% complete, short Furmark test is successful), 3. Playing Diablo 3 for about 15-20 minutes.
What I already checked:
1. Memtest left overnight, no problems detected.
2. Checked temperatures for overheating: in Furmark the lockup occurs at 65 degrees Celsius on one GPU and 58 on another (overheating seems unlikely).
3. All peripherals are at default values: no overclocking ever attempted.
My system:
Case: Silverstone FT-02
Motherboard: Gigabyte G1 Sniper 2
CPU: Intel I7-2700k
Memory: 4x4 sticks of Samsung 10600
GPU: Nvidia GTX 590
Audio: onboard Creative chip
Drives: SSD Intel 160 GB (OS drive and all programs are installed here) and WD 1.5 TB (solely as storage, no programs installed on it)
PSU: Chieftec APS-1000C
OS: Windows 7 64 bit
CPU and GPU are liquid cooled via single coolance waterloop and 3x section radiator placed on top of the 3xair penetrator fans of the Silverstone FT-02. Since the PSU is located at the top of the case where hot air is rising, the intake of the PSU is obviously facing outside the case (to get cool air) and then the air comes out from top of the PSU.
Overheating should not be the issue, since (despite single loop and not liquid cooling-friendly case) idle graphics card temps are 38/35 degrees Celsius, and around 65/58 degrees Celsius at max load.
I am puzzled and thinking about replacing the PSU. Or maybe it is some problem with SSD?
Thank you for reading this. Your help will be truly appreciated!
Anton
My system:
CPU: Intel I7-2700k
GPU: Nvidia GTX 590
Anton
