Solved
$500 build need help!
Last response: in Systems
Approximate Purchase Date: This week!
Budget Range: $500ish
System Usage from Most to Least Important: Gaming, surfing the internet, watching movies
Parts Not Required: keyboard, mouse, monitor
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: AMD and ATI
Overclocking: Maybe
SLI or Crossfire: No
Additional Comments: I won't be recycling any parts into this build. My main concern is compatibility since this is my first build and I want it as smooth as possible. Is the PSU enough for this build? Anyway to trim the cost a bit closer to 500 would also be nice.
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
ASRock M3A770DE AM3 AMD 770 ATX AMD Motherboard
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
-Combo-
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
XFX HD-685X-ZNFC Radeon HD 6850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity -combo with Shogun 2-
$561
More about : 500 build
rolli59 said:
If you drop either the HD5770 or the HD6850 you would trim some of the price! (Or which one is in the price?)
The BP550 is plenty for a single card setup!
Oops I replaced the 5770 with the 6850 and forgot to erase it so the price is still at $561.
Looks like a great build to me! You could probably still shave a few bucks here and there if you wanted to get really serious about getting down to your $500 guideline. Still, what you've picked looks pretty good.
Related ressources
You can trim $10 by going with this case instead
Xigmatek ASGARD II $29.99
You can save another 10 by going with this Antec Earth Watts (though non modular). You don't need more for this build.
Antec EarthWatts Green EA-430D $44.99
If you want to shave off anymore you're going to have to either drop down from a 6850 to a 6790, pick a cheaper hard drive, and/or get a cheaper CPU.
By the way, if you spend a little more on the motherboard you can get an AM3+ board and upgrade to Bulldozer latter on. That might make you feel better about getting and overclocking a slightly cheaper Athlon II X3 now ^_^
Ask the community
