Sound card not working
The audio port on my motherboard was recently broken after a family member tripped on the wire running into it. I went and bought a sound card, the Creative Sound Blaster Audigy SE. I tried installing but I can' t get the sound to work, im running Windows 7. I check if it would be compatible before buying and installed the drivers from the Creative site. Still can't get it to work.. Any suggestions? Thanks
2 answers Last reply
More about sound card working
  1. did you check to see if the Sound Blaster is the active audio device?
    Press or click the Start/Windows button. Type in the word "sound". Left click on the word "sound" in the results shown. This should bring you to the sound configuration panel.
  2. Thank you very much!
Sound Cards Creative Components
