G gamersbureau Honorable Jun 13, 2012 43 0 10,530 Jun 15, 2012 #1 Gigabyte GA-Z77X-D3H VS ASROCK Z68 EXTREME3 GEN3 Intel Which one should I get and Why?
A akxpckwb Distinguished Jan 24, 2012 820 0 19,160 Jun 15, 2012 #2 Main difference between them is the chipset. Z77 allows you to use PCIe 3.0 when using an Ivy Bridge CPU, has native 3.0 USB and allows the use of DDR3 up to 1600Mhz.If you don't care/need any of these get the ASRock. The Z68 will serve you well
Raiddinn Splendid Oct 21, 2011 5,123 0 26,460 Jun 15, 2012 #3 We would have to know what you had, but generally I would say get the Z77 if you are getting an Ivy Bridge processor and the Asrock if you aren't.
