Help - need motherboard
I need a mobo for an ASUS CM5570 - AP002, socket 775. Any suggestions? Wedgeguy
4 answers Last reply
More about help motherboard
  1. Without know anything else about what you have replaced or are going to replace here are a few good boards.
    ASUS P5G41T-M LX PLUS LGA 775 Intel G41 Micro ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131794
    ASRock G41M-S3 LGA 775 Intel G41 Micro ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157242
    If you are currently using DDR2 you can step up with these to DDR3 now.
  2. Those are DDR3 boards, he needs DDR2.
    This is the cheapest with free shipping.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813138183
    Yes that is correct.
    I just figured if your going to purchase new equipment might as well set up, get new RAM as well. He did not state he wanted new ram but I just wanted let him know that option is there. :)
  4. Yeah well I wouldn't recommend buying new ram if you already have ram.
Motherboards Asus Socket Product
