Hello everyone.
This will be my first time building a gaming dedicated PC and would like your help in putting it together.
My goal for this gaming rig is for it to be "high-end" enough that it'll still be decent in 2-3 yrs. time, and be able to upgrade and expand in between. Basically i want to have a powerful enough rig that i wont need to completely rebuild within that 2-3 yr. time frame. Price wise, i would like the best bang for my buck BUT am willing to shed more money where it will be best spent. Let me know if this goal is difficult to achieve. That being said, here is where im leaning towards with regards to hardware.
CPU - intel based. Since this is mainly for gaming, an i5 2500k processor should suffice?
Mobo - A P67 mobo. Perhaps a ASROck p67 Fatal1ty or p67 Extreme4. Or a P8P67 Pro or Deluxe perhaps?
VID card - My bro is crossfiring 2 XFX HD6850's. I have the option of taking one and adding another in the future. OR, you guys can suggest a better longer lasting option. I'm not too concerned about the manufacturer, and i dont want anything too high-end either. Options would be great.
RAM: G.Skill Ripjaws-X F3-12800CL9D-8GBXL???
CPU cooling - looking at a corsair h60, but open to suggestions
POWER SUPPLY - Bang for buck and will last
CASE - An ATX mid-tower. Not too concerned about style and flashiness. I want something that can hold everything, big enough that the inside wont be crowded, and great cooling features. Everything else comes second.
MONITOR - A 24" Widescreen with 1080p, 1920x1080 res, etc. Wont be dual displaying.
HARD DRIVE - looking at a Western Digital Caviar Green (WD20EARS) 2000GB (2TB) SATA 3 Gb/s 64MB (OEM).
BLUE-RAY DRIVE - Bang for buck.
I think thats about it. hopefully i was thorough enough and didnt forget anything. Pls also suggest other viable options where possible. I know its a lot of things to put together but any help is greatly appreciated. Again i'm looking for high end, energy efficient and bang for the buck at the same time...If thats even possible. :S
-Sid
-Sid
