Hello everyone,
I came across this site and did some reading but now I need some help.
I just moved out of the city to a rural area and my only option for internet is yourlink.ca which is wireless high speed with speeds up to 2mbps DL and 256 kbps UL speeds.
Now this is what my goal is:
House is approx 2000 sq ft split level
I will have the cat5 cable coming from the outside antenna that picks up the signal going into my office room located upstairs on my top level.
This will go to my wireless router (not sure which one to get yet) then a wired connection to my desktop in the same office room.
From here I would like wireless throughout the house all the way to the basement (has to pass through two floors to get to basement)
And also I would like to have wired connection in basement to my Xbox and blueray player. I also may add some wireless security cameras. Also would like to use apple airport express to stream tunes to my receiver via the apple remote app.
This is a older house with no cat wiring anywhere.
What can you suggest the best set up for me ? I plan to budget around $500.00 if possible.
Thanks for the help
Thanks for the help
