This motherboard adopts Intel® Z68 chipset that supports Serial ATA3 (SATA3) hard
disks and RAID (RAID 0, RAID 1, RAID 10, RAID 5, Intel Rapid Storage and Intel
Smart Response Technology) functions for SATA3_0 and SATA3_1 connectors. It
also adopts ASMedia ASM1061 chipset that supports Serial ATA3 (SATA3) hard
disks for SATA3_A1 to SATA3_A4 connectors. You may install SATA3 hard disks on
this motherboard for internal storage devices. This section will guide you to install
the SATA3 hard disks.
STEP
This motherboard adopts Intel® Z77 chipset that supports Serial ATA3 (SATA3) hard
disks and RAID (RAID 0, RAID 1, RAID 5, RAID 10, Intel Rapid Storage and Intel
ASMedia ASM1061 chipset supports Serial ATA3 (SATA3) hard disks for SATA3_A1
to SATA3_A4 connectors. You may install SATA3 hard disks on this motherboard for
internal storage devices. This section will guide you to install the SATA3 hard disks
if the ssd are in ports 0 and one the mb chipset if it in raid mode is going to think your going to raid them. if you plug it into the other chipset port it going to slow down. may want to check that you installed the newest intell rapid storage driver/intel chipset drivers and asmidia sata 3 driver.
