Hello,
I am Wordering how reversing the airflow in my case will work. Only reason im reversing it is bc i bought an h50 and i want cool air from outside the case blowing on it. Here the link for where i bought the case http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3433320
the fans i put in there are i got one 120mm on outside of case blowing in rear and another on the inside of the case blowing on the radiator then another on other side of radiator blowing to the front and then in the front i have two 80mm fans blowing out of the case where a 5.25 cd rom would be and another 100mm fan blowing out also just above them and i also have a 80mm blowing into the case from the side panel will there be a problem with this setup or anything
