Hi Everyone,
Have a i7 930 which is not overclocked or anything and just using the stock cooler however I had just noticed the other day that the temps at idle was stupidly high sitting at around the high 60's up to the 70 degree mark with the room temp being around 16 degrees, so I used Prime95 to put some load on it and found it jumped straight to the 100 degrees before i quickly killed the process.
Cannot see any reason for the temps to be so high, I checked that the heatsink was seated correctly and had enough paste but not too much and everything checks out fine, fans all seem to be running as normal as well. Jumped into Bios and reset to defaults just in case, and turned the turbo function off as well which made a little difference, temps now sitting at about 60ish idle which is still very high.
My case was a little dusty so also cleaned that out completed including filters, vid card, etc.
Specs:
i7 930
Gigabyte X58A-UD3R
ATI 5870 (moved to bottom of the case)
Antec Nine Hundred Two V3 Case (clean filters)
I will be getting a new HS/Fan soon enough but was wondering if there were any known issues with the stock cooler, or just any other thoughts at all.
Cheers
Specs:
i7 930
Gigabyte X58A-UD3R
Cheers
