Here's the PSU:
http://www.corsair.com/power-supply-units/enthusiast-series-power-supply-units/enthusiast-series-tx650-v2-80-plus-bronze-certified-650-watt-high-performance-power-supply.html
And the components in the PC are (the ones that I think matter the most anyway):
AMD Phenom™II X6 1100T
Asetek 510LC Liquid Cooling System
NVIDIA GeForce GTX 560 Ti 1 GB
8GB DDR3/1600MHz
The PSU is a 650W Corsair with 53 amps on the +12V rail. I'm almost positive this will run everything fine but it never hurts to double check with some smart people =)
If any additional info is needed I will provide it. Thanks guys
8GB DDR3/1600MHz
