New pc, need help with parts etc.
As the headline says, i am in a dire need of a new gaming pc. (so many new games i have not played yet)
And my knowledge of newer hardware is.... moderate at best. Last time i build my own pc was 7 years ago,
So i am as outdated as my old pc. :pfff:
The things i need help with:
-That every component actually fit/work well together
-Hardware of same quality/performance and cheaper (or better and slightly more expensive)
-Choosing power-supply and cpu cooler
-Other missing components
This is the components i have found so far to be interesting:
Core i7 2600k $314.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=core_i7_2600k-_-19-115-070-_-Product
ASUS P8Z68 Deluxe LGA $254.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131753&Tpk=P8Z68%20DELUXE
G.SKILL Sniper 8GB (2 x 4GB) $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417&cm_re=sniper_ram-_-20-231-417-_-Product
COOLER MASTER HAF 932 $154.48
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160&cm_re=coolermaster_haf_932-_-11-119-160-_-Product
ASUS Black 18X DVD-ROM $16.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135224&cm_re=dvd_drive-_-27-135-224-_-Product
Wintec N1 Series 33121323 2.5" 128GB $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820161373&cm_re=ssd_128gb-_-20-161-373-_-Product
SAPPHIRE Radeon HD 6950 $274.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102914&cm_re=Sapphire_Radeon_HD6950-_-14-102-914-_-Product
= 1266 $
Also, I am having some problems deciding on a graphic card, And if i should choose a ssd-HD 64 or 128 gb.
Im thinking of price versus performance.
Any help would greatly be appriciated. :hello:
P.s. I live in sweden atm. so some parts might be unavailable.
Sincerely Thomas.
7 answers Last reply
More about parts
  1. yeah all of the items above look alright and compatible. DON'T FORGET THE POWER SUPPLY!
    Also, for graphics cards, you could go with what you have, or the next upgrade, the 6970. Or, a Geforce GTX 560/570. They all offer about the same range of performance.
  2. Wouldnt it be silly to spend almost the double on the 6970, when this card don´t perform that much better.
    But the EVGA GeForce GTX 570 HD 1280MB PhysX, that might be a good choice, noticeably better than the one i picked and 15-20% more expensive.
    What im really asking is, will this setup work well in games like resident evil5/crysis etc.
    (Games that wont work on any system)
    And about the power supply, as i remember, not all power-supplies have the correct cables for graphic-cards, motherboards etc. This might be something i picked up at LIE-mart :P
    And the last thing ive been thinking about, is the cpu-cooling-fan. i have read a few reviews, but cant seem to make up my mind.. so many fancy ones, but i know i shouldnt go for the UUUH SHIIIINY :non:
    Thomas.
  3. For gaming the i7-2600K is overkill the i5-2500K is the CPU of Choice.
    http://www.tomshardware.com/reviews/best-gaming-cpu,2951.html
    For a PSU you need to know if you will SLI/CF or just stay with a single GPU
    single GPU = ~600-650w if you are going CF/SLI then 750-850W. stay with name brands like Seasonic, Corsair, Silverstone, Antec and even the XFX Core series (OEM is Seasonic)
    GPU is a good one.
    That Motherboard is way over kill for basic gaming the Z68 chipset is highend and offers no extra FPS for gaming. save youself some money and get a P67 chipset MB or at least a Value oriented z68 MB.
    http://www.tomshardware.com/reviews/asrock-z68-extreme4-asus-p8z68-v-pro-gigabyte-z68x-ud3h-b3,2939-12.html
    Suggested MB:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128493
    For SSD, if you plan to game on it get the biggest you can. check the reviews. That wintec N1 is bad news stay away from it!
    Suggestions:
    SAMSUNG 470 Series MZ-5PA128
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820147063
    Crucial M4 CT128M4SSD2CCA
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
    read about SSD's:
    http://www.tomshardware.com/reviews/best-ssd-price-per-gb-ssd-performance,2942.html
  4. Assuming you will be gaming and have a budget of $1400 or less, here's a built with OS :
    CPU & GPU : $555- i5-2500K & Asus GTX570 DCII (Great processor and great video card)
    You don't need an i7-2600K for gaming. Hyperthreading of i7 is of no use in gaming . Here's a review
    Motherboard : $140- Gigabyte GA-Z68X (Capable motherboard with SSD caching support )
    SSD: $230- OCZ Agility 3 120GB (Better SSD than Wintec.Here's a review)
    Power Supply : $135- Corsair Enthusiast TX850 (Ample power to support dual 570 )
    Case : $100- Cooler Master HAF 922 (Stripped down version of 932 but good)
    HDD: $60 - Seagate Barracuda 1TB or Samsung Spinpoint 1TB
    RAM: $65- Patriot Signature (2X 4GB) (Cheap)
    Optical Drive : $20- Asus
    OS : $95- Windows 7 Home Premium SP1 (64bit)
    Total (Excluding Rebates): $1385
    Rebates : $50
    If you don't want GTX570 a similarly priced card will be like Sapphire Radeon 6970
    If you have an OS, no need to get one drop it and save $95.
  5. Thank you for the thorough replies, much appreciated :)
    You tell me the i7 cpu and the motherboard i chose was overkill, but wouldnt it also prepare me for the "future"?
    Again thanks for all the parts recommendation
  6. Me again, these are the components ive decided on, any objections :) ???
    And sorry about the swedish links, these are the sites im going to buy them from.
    I will be going for the I7 2600k, but im not sure about the motherboard.
    So, will this motherboard ensure me being up to date in the nearest future, or wont it mean a dang diddly squad?
    http://www.prisjakt.nu/produkt.php?p=873561
    http://www.webhallen.com/hardvara/127474-intel_core_i7-2600k_3.4ghz-8mb-socket_1155
    http://www.proshop.se/Moderkort/ASUS-P8Z68-DELUXE-Sandy-Bridge-2258186.html&ref=prisjakt
    http://www.prisjakt.nu/produkt.php?p=611035
    http://www.alina.se/Produkt.aspx?site=prisjakt&T2=F3-12800CL9D-8GBSR2
    http://www.komplett.se/k/ki.aspx?sku=638546
    http://www.alina.se/Produkt.aspx?site=prisjakt&T2=0761345-06880-2
    The Antec's CP series Power Supply is exclusively designed for Antec's 1200/P183/P193. May not fit your CASE!
    Any of these will work though:
    http://www.proshop.se/Stromforsorjning/Antec-High-Current-Gamer-HCG-750-750W-2234753.html
    http://www.webhallen.com/hardvara/98833-antec_powersupply_750w_truepower_blue
    http://www.webhallen.com/hardvara/124158-antec_powersupply_high_current_gamer_900w
    http://www.webhallen.com/hardvara/77589-antec_powersupply_850w_truepower_quattro
    http://www.webhallen.com/hardvara/98232-corsair_powersupply_750w_hx
    http://www.webhallen.com/hardvara/126880-corsair_powersupply_800w_gaming_series_80_plus
    http://www.webhallen.com/hardvara/129360-corsair_powersupply_850w_enthusiast_series
    I would also go with this MB:
    http://www.proshop.se/Moderkort/ASRock-Z68-Extreme4-Sandy-Bridge-2258182.html
    Z68 MB review on Tom's
    http://www.tomshardware.com/reviews/asrock-z68-extreme4-asus-p8z68-v-pro-gigabyte-z68x-ud3h-b3,2939.html
    I'm not sure the RAM you picked out is compatible. The website says its SO-DIMM and at 1.25v not DIMM at 1.5v Might be a misprint though, the Pic looks like DIMM modules. http://www.alina.se/Produkt.aspx?site=prisjakt&T2=F3-12800CL9D-8GBSR2
    regardless I would get these instead and save yourself some $:
    http://www.proshop.se/RAM/G.Skill-8GB-DDR3-1600MHz-(2x4)-2279646.html
New Build Systems Product
