I am going to build my next gaming computer. Primary purpose of computer is to game with a little movie watching and surfing the net. Last computer I built was a 486 back in the 90’s. I have picked the AMD Phenom II as my processor. Below is the FYI to help guide me on a mother board.
Time Frame - 1-2 Months
Location - USA
Total Price range $1300-$1600 for pc only. Not including shipping or rebates
Have not looked into over clocking, but might be an option.
AMD Phenom II 970, 975 or 980. Have not decided on what one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103894&Tpk=AMd%20Phenom%20II%20970 $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103923&Tpk=AMd%20Phenom%20II%20975 $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103934&Tpk=AMd%20Phenom%20II%20980 $190
Ram
16 GB of ram
Video Card
Radeon HD 6970 2GB one card. I will only be using 1 27” Monitor. I might hook up a 21” later. I have no plans to upgrade to 2 video cards. $350ish-$400 depending on manufacture.
Power Supply –
CORSAIR Enthusiast Series TX850 V2 850W $135
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022&cm_re=CORSAIR_Enthusiast_Series_TX850_V2_850W-_-17-139-022-_-Product
CORSAIR Professional Series HX1050 1050W $230
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139034&Tpk=CORSAIR%20Professional%20Series%20HX1050%201050W
CPU Fan still researching
COOLER MASTER Hyper 212 Plus RR-B10 $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=Coolermaster%20Hyper%20212%20plus
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm $60
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055&Tpk=coolermaster%20v8
Case still researching.
Will upgrade sound card later. Or if suggested worth doing now will added in budget.
Deciding on upgrading network card or not. Is this worth doing? Router will have Wii and total of 2 comps hooked up. No wireless involved.
I Might get a TV turner. So number of PCI slots could determine motherboard.
Hard drive will be 1-2 tb. Been looking at doing the 2 1t hard drives. does this healp that much on a gaming system.
Optical Drive a blue ray burner
Here are the mother boards I have seen and liked. Any suggested on which one would be better or another motherboard instead would be great.
Mortherboard
ASUS M5A99X EVO $155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131754&Tpk=ASUS%20M5A99X%20EVO
ASUS CROSSHAIR V FORUMLA 990FX $240
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131735&Tpk=ASUS%20CROSSHAIR%20V%20FORUMLA%20990FX
MSI 890FXA-GD70 AM3 AMD 890FX $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130274&Tpk=MSI%20890%20FXA-%20Gd70
Sorry for the long winded request for help.
Location - USA
Ram
16 GB of ram
Video Card
Power Supply –
Mortherboard
