Archived from groups: alt.sys.pc-clone.dell,comp.sys.laptops (
More info?)
If you use a pencil eraser to clean contacts, use a brand called "Magic
Rub" (very common, actually, any office store will sell them). Most
other erasers are abrasive and will remove gold or other platings from
contacts.
Kevin Childers wrote:
> Try using a pencil eraser to clean the contacts off? Usually works for
> light corrosion, etc.
> KC
> "Tom Simchak" <not.today@thankyou.org> wrote in message
> news:eSAue.1732$W74.116@newssvr30.news.prodigy.com...
>>Tim--
>>I too have an I5000. Same thing...battery not kicking in when A/C is
>>unplugged. What it took, and I do not advocate force in most
>>situations, is a FIRM slam of the battery into the computer. Also,
>>check out the contacts inside the housing. They may be slightly
>>corroded and need to be cleaned. Now the battery works like a charm.
>>Tom S.
>>Houston, TX
>>DiezMon wrote:
>>>Hello all,
>>>Sorry for the cross post but I'm at my wits end on this. I've googled
> up
>>>the wazoo and can't find an answer
>>>I have an I5000 that I bought from an old place of employment. About a
>>>month ago I noticed that when I unplug from AC, it shuts right off. The
>>>battery doesn't kick in. I've tried different batteries that I know are
>>>good...
>>>When I check the batter in the "Power Options Properties" I see the
> icon
>>>for the battery, but it's got a red X through it. If I then click that
> icon
>>>to see properties, it says it's online.
>>>So, is it either that the battery is never taking a charge, or some
> other
>>>hdwr problem? How can I check of the laptop is actually charging the
>>>battery?
>>>Has anyone else experienced this? Can someone point me in the right
>>>direction to fix it?
>>>Thanks!
>>>Tim
