Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Gericom Overdose 3 Jumper dip switch config ?? any body ha..
Forum Laptops & Notebooks : General Laptops & Notebooks - Gericom Overdose 3 Jumper dip switch config ?? any body ha..
Archived from groups: comp.sys.laptops (More info?)
search for an manual for my Gericom overdosee 3 Laptop
I found 6 dip swich but i cant justage : 1000 Mhz / 100Mhz Bus/takt ????
THX
Wolfman
Sponsored Links
> THX
> Wolfman
The dip switch on the mainboard is typically used for setting monitor
properties. Unless there is a setting for modifying the FSB in BIOS
setup, you will be out of luck since these are set in the hardware and
are not user modifiable.
If I understood what you are asking, that is.
Q
Reply to Anonymous
>>THX
>>Wolfman
> Q
THX but this is the 4 dip switch ..... i have a 2nd one with 6
switch ????
can any help ?? :o)
Thanks ..
Wolfman
Reply to Anonymous
There are 1270 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
