If you guys have ever seen an ASRock Extreme 4 mobo then you know there are 6 obvious screw/mounting holes along the left side & down the middle of the board.
My question is, is the hole in the top right of the motherboard meant to meet a standoff & be screwed down there too?
In the manual it says that these holes are designated by an obvious white circle, this top right screw hole is the only one that isn't so I'm not sure and would like a definitive answer, thanks.
