Archived from groups: comp.sys.laptops (More info?)
In article <amztbeh6ztwy.dlg@eddie.co.uk>,
Eddie <edimodric@makni.inet.hr> wrote:
>Hello everyone!
>I'm wondering what is the best way to store the battery when i'm using my
>laptop on AC power (which is most of the time anyways).
>Do I keep it charged or discharged and should I use it from time to time?
If it's lithium-ion, as most new laptop batteries are, the optimal state
for long-term storage is at 40% - 60% charge.
The consensus is to remove the battery from the laptop. All of the
battery mfgrs. seem to recommend that lithium batteries be stored at 40%
to 60% charge, although I've stored them at full charge with no obvious
ill effects. Sony recommends storage at full charge for lithium
camcorder batteries, and a refresh cycle (not below 25% to 30%) about
once every 90 days.
Eddie wrote:
> Hello everyone!
> Thanks for your answers!
Opinions are mixed on battery storage. I keep my batteries attached all the
time and they're mostly on AC. Both Thinkpad batteries are original - 7
y.o. 560X and a 4 y.o. T22 - and they both hold sufficient charge for my
purposes - at least 45 minutes. A key advantage of keeping the battery in
the laptop is protection of data in case of power loss. YMMV.
> once every 90 days.
> Eddie wrote:
>> Hello everyone!
I saw some test data that suggested there's a BIG difference in storage
deterioriation between 40% and 100% initial charge at high temperatures.
By the time you get down to just above 0C, it doesn't seem to matter
what the initial charge.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
You are lucky.
Yes, the battery makes a nice UPS. But a new one is often $200. You
can buy a real UPS for $30 or less.
I think we can all agree that for this purpose, whatever the initial
charge, the storage will be at "room temperature".
>> 40% to 60% charge, although I've stored them at full charge with no
>> obvious ill effects. Sony recommends storage at full charge for
>> lithium camcorder batteries, and a refresh cycle (not below 25% to
>> 30%) about once every 90 days.
>> Eddie wrote:
>>> Hello everyone!
>>> using my
>>> time?
> mike
That's pretty #$#%# presumptious of you!
Data indicates that storing in the fridge (maybe) lengthens storage life.
Mine are ALL stored in the fridge.
So, no, we don't ALL agree!!!
mike
>>> Eddie wrote:
>>>> Hello everyone!
>>>> using my
>>>> time?
>> mike
"Barry Watzman" <WatzmanNOSPAM@neo.rr.com> wrote in message
news:42BE1A3B.1000400@neo.rr.com...
> You are lucky.
That's true and I certainly have one for my desktop PC. However, for me,
much of the utility of a laptop is the ability to take it with me whether
it's to another room or to another country. Lugging around a UPS wherever I
go is not really feasible or desirable.
No arugment, the battery is there for a purpose. But that purpose isn't
to be a UPS when the laptop is NOT mobile and is plugged into the AC
power lines 24x7 at one single site. You can use it for that purpose,
but doing so can be awfully expensive.
>>You are lucky.
"Mike S." <retsuhcs@xinap.moc> wrote in message
news9gvlg$p5b$1@reader1.panix.com...
> >Hello everyone!
.... and the optimal storage temperature is 5 deg C. Basically keep it in
the fridge. But do not put it in the freezer, or you will destroy it (the
battery that is - oh, and come to think of it, the freezer as well).
Check the charge periodically (say every 3 months and charge as necessary).
Li-ion batteries hold their charge extremely well.
