Hay i got a new grafikcard and i got extrem frame lagg ati radeon 5770
hi i got Operating System
MS Windows 7 Home Premium 64-bit SP1
CPU
AMD Phenom II X2 545 36 °C
Callisto 45nm Technology
RAM
6.0GB Dual-Channel DDR3 @ 533MHz (7-7-7-20)
Motherboard
Acer FRX780M (CPU 1) 30 °C
Graphics
Compaq Q2159 (1920x1080@60Hz)
ATI Radeon HD 5700 Series
Hard Drives
733GB Western Digital WDC WD7501AALS-00J7B0 ATA Device (SATA) 47 °C
Optical Drives
ATAPI DVD A DH16AASH ATA Device
Audio
AMD High Definition Audio Device
and i got extrem frame lag on modern warfare 2 and black ops i buyed the grafikcard 2 weeks ago and my old one ran modern warfare 2 on high grafik with out a problem and now i m sitting at home and wondering is it my computer or my grafikcard that sucks? anyone know how to solve the problem i would be thankful!
6 answers Last reply
More about grafikcard extrem frame lagg radeon 5770
  1. Did you uninstall your old graphics drivers and install the latest driver from ATI's website for HD5770?
  2. A good rule of thumb is to uninstall your old drivers (using the driver software like AMD Catalyst). Then run a program like Driver Sweeper to clean out any residual drivers that it may have missed. Reboot and install the new drivers. See if that works for you.
  3. i reinstalled window 7 so i got only my new grafik driver nothing else
  4. DDR3 at 533 MHZ?
    And yes, reinstall drivers. Or maybe OS if it doesn't work see here for instructions.
    http://www.tomshardware.com/news/the-oatmeal-how-to-fix-computer,12618.html
  5. It was working ok before so...what was the previous graphics card you had installed? maybe what you thought was an upgrade, actually was not.
  6. it was a ati radeon 4600 series it sucked so i dont think 5770 is worse
Graphics Cards Graphics
