So I have the above stated CPU cooler on a AsRock Extreme 4 Gen3 board with an i5-2500k overclocked to 4.4ghz. The cooler runs great, it keeps my cpu under 64C after a couple hours in prime95 small ftts.
I have a small problem with it though, IT FREAKING VIBRATES LIKE CRAZY.. Recently the cpu itself started vibrating inside my 600t se. It vibrated to the point that I could hear it ticking and it is VERY very annoying. I noticed that it seems to happen more and more as the fan speeds up when I am gaming. I have tried uninstalling it and reinstalling it, tightening the screws more or whatever, a couple of times, but the same problem persists. I know its the cooler too because i can just open my case and put my finger on the fins and the rattling/noise stops.
Anyone experienced this with this cooler and what can I possibly do to calm it down. I really don't want to spend another $60 to get another cooler and I can't return it cause I already sent the UPC code for a rebate >.<
