Hello,
I'm looking for an inexpensive motherboard with these specifications:
LGA 1155
Firewire port
1 PCI Express 16x slot
PCI Express 1x Slot
HDMI
DDR3 at least 16 Gigs
Only 1 SATA III
I'm planing on putting an intel i3 2100 with the motherboard now, then eventually upgrading to an i7. Besides everyday computing needs I'll be using the computer for watching HD and blue-ray movies, light photo editing, and light gaming. I would also really like the system to run pretty quickly. I cant find any motherboards that are relatively inexpensive with these specs. All I can find is other mobo that have other more advanced specs that I don't need (making them more expensive), or ones that don't meet the specs I would like, suggestions would be greatly appreciated. Cheaper the better.
LGA 1155
Firewire port
PCI Express 1x Slot
HDMI
Only 1 SATA III
