Hello all,
I built my rig just over 8 weeks ago and its been running fine and last night I switched it off and went out as usual. Came back to find that it won't boot. I have it open and the motherboard P8Z68 V-PRO board shows the power light and the reset button with power. When pressing the power button the top case fan turns a quarter turn and stops and the lights stay as they are and nothing else happens. There is obviously a fault here but don't know what it is at present. Any ideas before I get onto the place that supplied me with the parts.
Thanks
Rikk
Rig
Haff 922 case
Intel I5 2500k
Asus P8 Z68-VPRO Motherboard
Radeon HD 6950 2gb 5000Mhz GPU
Samsung Spinpoint F3 1TB hard Drive
Corsair TX 750 Power Supply
8gb Corsair Vengence Ram
Dark Rock Be Quiet Advanced Fan
Sony DVD RW
Thanks
Rikk
Rig
Haff 922 case
Intel I5 2500k
Sony DVD RW
