What cable do I need???? gtx 570 and dell monitor
wwowz
17
Hey guys! I am almost done with getting the parts for my first new rig!
However, I came up with a question regarding the cable between my dell st2220m 21.5 HD monitor.
http://accessories.dell.com/sna/products/Monitors_Flat_Panel_Widescreen/productdetail.aspx?c=ca&l=en&cs=cadhs1&sku=320-9332&baynote_bnrank=1&baynote_irrank=0&~ck=baynoteSearch
Apparently, this monitor does not support HDMI connectivity (according to the website) and the dvi cable is NOT included :(
So I need a cable to connect my monitor to my gtx 570. What is the best way to connect these 2 bad boys together?
edit: http://www.bestbuy.ca/en-CA/product/rocketfish-rocketfish-2-4m-8-ft-dvi-cable-rf-pcc119-rf-pcc119/10145388.aspx?path=0188aa7b44d4b8cc3fc85ca85c11cebcen02
Will this work? any thoughts?
Thanks in advance guys!
And dell did not include any display cables either?
Anyway you're looking for a dvi cable and I would advise you to buy a cheap one. It's not like you have 1000+ dollar monitor anyway so no sense in spending extra cash on something you're not going to notice.
Mrsh4dy
105
