Hello, After replacing failed hard drive in Dell Dimension 3000, when I try to boot it says Primary drive 1 not found. I have reset the known good used drive to master by removing jumper. I can go into set up and it recognizes it there. I have changed the boot sequence so it boots from CD rom and tried using windows XP disc to boot and still get Primary Drive 1 not found message.
