Yes No
Ads
Tom's Hardware > Forum > Systems > Prebuilt > Small PC Upgrade Help?
Forum Systems : Prebuilt Small PC Upgrade Help?
My current PC is an HP Pavilion Magnesium Gray Edition p6654y. I plan on upgrading the CPU to an AMD Phenom II X4 945 Deneb Core 3.0GHz Processor and the GPU to a EVGA GeForce GTX 560 Ti Superclocked video card. I had a bad experience with using a reference Nvidia Geforce GTX 560 Ti for my PC. It caused 2 BSODs in one day(returned it the same day). I think it might have been bottlenecking my CPU. So, should I go with the upgrade? I'm afraid I'll have the same issue with the non-reference card. If so, what Radeon HD card would you recommend that is of equal or greater performance than the GTX 560 Ti? By the way, I use my PC for gaming, school work, and everyday tasks, just so you know. My budget for the CPU and GPU is $670 (I don't want to spend ALL of it).
Message edited by AbdullahG on 07-07-2011 at 01:48:51 AM
Reply to AbdullahG
You may need a psu upgrade also.
The GTX560Ti needs 500w with 30a on the 12v rails plus two 6-pin PCI-E power leads.
Most pre built pc's come with a psu only strong enough to power the original configuration.
BSOD could be a number of reasons:
Insufficient power, driver problem, defective unit.
But being "bottlenecked" by a slow cpu is not one of them.
A amd card equivalent to the GTX560Ti might be the 6950.
Reply to geofelt
I actually have a 600W PSU, so that's no issue (now that I think about it, the BSODs probably were caused by overloading my PC with so many tasks at one time). I'm still wondering if I should try my luck with the 560 Ti (not going to try the GTX 570 or 580; too much power consumption).
Message edited by AbdullahG on 07-07-2011 at 02:39:25 AM
Reply to AbdullahG
There are 1825 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 45 minutes ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
