Closed Solved
Custom PC Randomly shuts down and will not power back on!!! HELP!
i was installing a card reader to my computer. wen i turned it back on to test it it shut down after 5 sec. i was having problems with it before i had a power surge and it corrupted some stuff well its from 2004-5 1.66 gh 1gb ram 60 gb hard drive im a computer colector so i dont want it to die! (lots of computers from its age group have bad whatever those blue tubes are called so that cude be the problem) if you have a sulushin plz email me at the motherboard is an asrock k7s8xe and the power suply is a codegen 200xa1
3 answers Last reply Best Answer
More about custom randomly shuts power back help
  1. Best answer
    Sounds like the power supply. Not the best of brands.
  2. Best answer selected by beny1000.
  3. This topic has been closed by Nikorr
ASRock Computer Motherboards
