Hello,
I'd really appreciate if someone would give me some suggestions about what could be wrong with my computer build. I have connected everything I believe should be connected, and I can turn the system on, but when I connect it to a monitor it just says "Check signal cable" or "No input." All the fans are spinning and motherboard light is on, optical drive works fine. The case is lighting up and it looks as if it is all working okay except for it says "Check signal cable".
Can anyone give me some suggestions as to what the problem may be?
I'd REALLY appreciate any help.
Sorry if I haven't made myself very clear but if you require more information please ask.
Cheers!
-Darren
Cheers!
-Darren
