First build. No POST. Tried the troubleshoot. Help!
Hi,
Im doing my first custom build today.
I installed the CPU, RAM, GPU and hooked up the PSU to the ATX, the ATX 12 and the GPU.
Then I turned on the motherboard. No beep!! I knew it wouldnt be so easy.
So I started removing bits. I got down to just the cpu (and cooler) with the ATX and Atx 12 plugged it.
If i switch on the motherboard with this set up the cpu fan runs, and all LED turn on and stay on. It keeps running like this until I switch it off.
Now, If I remove the ATX12 power and turn on the mobo it boots, runs for a sec (fan and LEDs) and then turns off, it trys a couple of times to turn on after this.
If I try to boot without the cpu installed and both ATXs it does the same (runs momentarily)
Whats the problem?
Any help would really be appreciated.
Oh the motherboard is a Gigabyte GA Z68AP D3 and the CPU is an Intel i5 3570k. The PSU is a cheap CIT 750w psu.
1 answer Last reply
More about first build post troubleshoot help
  1. Sorry for the double post. I said if i turn on the mobo with both atxs and the cpu installed it runs till i turn it off. Correction: It runs for about 10 secs then shuts down then starts again and repeats.
    CPU overheating?
Motherboards CPUs ATX Build
