Solved
Sound card + 6 rca adapters from home theater system = how do i do it?
  • Sound Cards
  • Home Theatre
  • Components
Last response: in Components
October 6, 2011 5:14:54 AM
Hi,
I am in the process of building my own gaming computer and have decided on a creative labs sound blaster x fi titanium fatal1ty champion series sound card. I chose this just because it is a well known card for gamers world wide and got good reviews.
Today i went downstairs and noticed we had a home theater system we never installed because we didnt want to rip out the carpet to do the wiring and id like to use this home theater system with my computer if possible. its by the brand prima and its model number is HT-Tw57P
I hooked it all up and the speakers and cords. the dvd player is broken but i wont be useing it anyway, but when tapping the 6 rca cords i do get a little sound from each of the 4 speakers as well as the center and sub woofer so it is all hooked up propperly. I was just wondering....how the heck to i fit 6 rca cords onto this sound card. is there a different sound card you would recomend. would i need a spechial adapter and would it even all fit then. and is plugging 6 rca cords into a sound card even possible.
thanks for any and all help. im stuck till i get an answer, and sorry for the typos, was in a rush.
that thread title should say acr cords not adapters...whoops
More about : sound card rca adapters home theater system
October 6, 2011 7:27:51 AM
Send the website links to the home theater system. We'll help you out after that.
m
l
Best solution
October 6, 2011 11:59:58 AM
All you really need is to use several RCA->3.5mm converter cables. The connector that soundcards use (TRS) carries two audio channels, where RCA carries only one. So you would need a converter cable for every two RCA connections.
October 9, 2011 8:21:05 PM
Best answer selected by zackb-m.
m
l
October 9, 2011 8:24:40 PM
thanks that helps a lot. i will be looking for the converters then. so these 3.5mm jacks would just be the line out 1-4 on the creative labs sound blaster x fi titanium fatal1ty champion series correct?
http://us.store.creative.com/Creative-Sound-Blaster-XFi...
or would i need something different?
m
l
October 9, 2011 8:25:48 PM
fine illcall u lazy haha sorry i didnt have the exact model of the home theater system, but 6 acr cables into this sund card is pretty direct
thats all i needed to know but i think the other person pretty much answered what i needed, thanks anyway!
m
l
October 10, 2011 12:55:40 AM
Theres not a whole lots of sense hooking a decent soundcard to such a low end HT system imo. I would suggest you use the onboard sound first and if that doesnt suit your listening needs then go ahead and purchase a sound card.
m
l
