Solved
I5-2500 build need advice b4 buying parts!!!
I got all the parts pick out i just need ur advice and input and will all parts work together?
Case-http://www.newegg.com/Product/Product.aspx?Item=N82E16811133094 $40
CD / DVD Burners-http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216 free
Hard Drives-http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185 $50
Memory-http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277 $46
Microsoft Windows 7 Home Premium SP1 64-bit $100
CPUs & Motherboards Combo deal- http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.679696 $277
Video card its going to be a 6850 or 6870
I need advice b4 i buy today plz!!!
5 answers Last reply Best Answer
More about 2500 build advice buying parts
  1. You don't have a power supply listed. Get one from Antec, Corsair, Seasonic or XFX.
    The XFX Core Pro650W $89.99 ( $59.99 after rebate ) is good but you can get by with less.
    500-650W is the range you should be looking at.
    GPU: Sapphire 6870 $174.99 for example will do nicely.
    The stuff you have listed will work together just fine.
  2. i have a Thermaltake TR2 600W ATX power supply already and i want to ask is there like a $80-$120 crossfir or sli Motherboard or a cheap,cheap crossfir or sli $120 or less? b/c if there is then i can add othere 6850 or 6870,thx
  3. Best answer
    GIGABYTE GA-Z68A-D3H-B3 $129.99 supports SLI/Crossfire
    So it's close if you can stretch the extra $10, Maybe go to i5 2400 on the CPU.
  4. thx alot
  5. Best answer selected by smokey66.
New Build Systems Product
