Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Toughbook 34 reverse polarity problem
Forum Laptops & Notebooks : General Laptops & Notebooks - Toughbook 34 reverse polarity problem
Archived from groups: comp.sys.laptops (More info?)
Hi All,
I stupidly connected a third-part power supply to my Toughbook CF-M34 today
with the wrong polarity.
I quickly removed the plug as soon as I smelt burning electrics (about 10
seconds).
All appeared ok at first, but then I realised the batteries won't charge and
it won't run on AC power either. I'm left with the few hours battery life in
my remaining charged batteries. After that it becomes a paperweight.
I'm assuming that there is a sacrificial fuse or diode that has burnt out.
Anybody had something similar happen to them or know of a solution? I'd like
to get the parts myself and sort it out ideally.
Cheers,
TB
Sponsored Links
TB wrote:
> Hi All,
> today with the wrong polarity.
> (about 10 seconds).
> charge and it won't run on AC power either. I'm left with the few
> hours battery life in my remaining charged batteries. After that it
> out.
> I'd like to get the parts myself and sort it out ideally.
> Cheers,
> TB
Probably the main power supply fuse. You'll have to open the case to
determine what might be done. I've used commercial quick opening fuses
of the correct amperage soldered across the blown fuse terminals
successfully. If you had a hot electronics odor, all bets might be off.
Q
Reply to Anonymous
The realistic truth is that you are probably in for a motherboard
replacement, unless the power supply is a separate module (which is the
case in a few machines, but not very many). You will most likely be
able to get neither the necessary information nor the parts themselves,
and if you smelled stuff, it's more than just a fuse.
TB wrote:
> Hi All,
> seconds).
> Cheers,
> TB
Reply to Anonymous
- 0 +
Thanks for your help guys. I'll try to get hold of a new fuse, but I'll
prepare myself for the worse.
TB
"Barry Watzman" <WatzmanNOSPAM@neo.rr.com> wrote in message
news:42C480AB.7040705@neo.rr.com...
> case in a few machines, but not very many). You will most likely be able
> to get neither the necessary information nor the parts themselves, and if
> TB wrote:
>> Hi All,
>> today
>> seconds).
>> and
>> in
>> out.
>> like
>> Cheers,
>> TB
Reply to TB
- 0 +
Correction £4 each for quantities up to10. Still happy!
TB
Reply to TB
There are 1208 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
