Solved
Need to replace an Ultra X2 750w power supply. Any suggestions?
  • Power Supplies
  • Hard Drives
  • Nvidia
  • Components
  • Product
Last response: in Components
October 7, 2011 3:42:44 AM
My power supply just died on me. It was an Ultra X2 750w. Specs as follows.
nvidia nforce 680i
Q6600 processer
4 gigs of ram (4x1)
2 8800gt in SLI
2 500g hard drives
More about : replace ultra 750w power supply suggestions
Best solution
a b ) Power supply
October 7, 2011 4:01:33 AM
Budget?
8800GT does not use much power actually. Are you upgrading any time soon?
There's a good deal on a quality PSU
High end Seasonic
a b ) Power supply
a b Î Nvidia
October 7, 2011 4:19:08 AM
and if you're going to be upgrading in future and have big monsters such as the GTX 570s, so a 750W is your best choice
NZXT Hale90 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
and it's the same price and efficiency as the recommended one above
m
l
a b ) Power supply
October 7, 2011 4:52:56 AM
Although the NZXT Hale is a good unit; the efficiency of the seasonic unit is much higher (88% / ~92%/ 87%) compared to (~85%,87%,86%) of the nzxt unit.
Both the Seasonic X and the Nzxt kingwin based units are good psu's but i'd still prefer the seasonic if you go with the high end stuff because it's seasonic... nuff said.
m
l
October 7, 2011 11:41:06 AM
Best answer selected by Tinlizard.
m
l
