Smps fan is not working but supplying power to the motherboard
enosh
Hello,
my cpu is not starting and smps also not working but led on the motherboard is on.
please help me what can i do for start the cpu
sashareef
same problem but no one is helping out in this blog .... please reply us ASAP ....
my sys is not working at all but when i ground black and green wire of smps fan is running so its not the problem of smps so there should be wrong with my motherboard but when i connect smps a light is showing which means my mother board is getting power .. so please let us know what the problem is and how to rectify it ..... thank you
kakaggarwal
Try using someone else SMPS for your motherboard, just consider the voltage specifications on both the SMPS then do this(i mean if they match then), if your motherboard works fine there then its okay if not then change it its dead. There are multiple circuits on motherboard may be it's some circuit is not working but circuit for showing power supply LED indication is working.
