Ok so I have got all the parts but someone said to make sure that the parts are all compatible with win7 64bit which I have no idea how to do....
Anyway... now I am all freaked out and not sure if everything will be compatible.
Here is my setup:
- Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
- Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7/Core i5" Power Supply
- Acer P215HBbd Black 21.5" Full HD WideScreen LCD Monitor
- SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
- Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
- GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- XIGMATEK Gaia SD1283 120mm Long Life Bearing CPU Cooler bracket included I7 i5 775 1155 AMD and dual fan push pull compatible
- ASUS ENGTX560 DCII OC/2DI/1GD5 GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
- LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
I just need someone to review this setup and make sure it will go well with win7 64bit and if I should run into any compatibility issues?
thanks,
Tanner
Here is my setup:
thanks,
Tanner
